Hello,
I couldn't find charts on frequency response and Impedance charts for the BC17 (RIGA)
I would appreciate it if someone could post all the available measurement/charts associated with BC17/RIGA.
Thanks in advance
RIGA - BC17 chart measurements - Tech data
Re: RIGA - BC17 chart measurements - Tech data
Haut-parleur : 1 x coaxial BC17
Efficacité 1W/1m : 90 dB
Fréquence de coupure : 1 600 Hz
Réponse en fréquence : 95 — 20 000Hz
Impédance nom./min : 8/4,1ohms
Puissance admissible nom./crête 150/1000W
Riga murale:
Finitions: Perle Noire - Perle
Dimensions : 22 x 22 x 27 cm
Poids : 6 kg
Riga murale:
Poids : 6 kg
Thank you,
But i was looking for data sheets like these but for BC17/RIGA :
(these are for the Cabasse Baltic for example):
Cabasse Baltic impedance chart:
http://www.google.co.il/url?sa=i&source ... 3165898493
This type of technical data sheet doesn't exist anymore for current products. You will have to find independant reviews, like here (click the "Presse" tab) : http://www2.cabasse.com/cabfx2012/riga- ... antorin-30
